- Sam_SpadeExplorer
Chum lee wrote:
I was totally amazed once when my li-ion portable battery booster actually jump started an older GM V8 diesel with totally dead wet cell batteries. (2-12 volt starting batteries from the factory)
Chum lee
There are varying degrees of "totally dead".
The small packs depend on the internal battery still being partly functional. They also depend on the stricken vehicle being fairly healthy so it will start right away.
I bet you wouldn't have fared so good if they had gone OPEN.....so that they couldn't help supply any current at all.
OR if it was -30 F and the engine was about 10 years beyond needing a tune up. - Chum_leeExplorerCheck the actual wire gauge of your jumper cables. Don't be fooled by thick insulation. Copper "looking" cables aren't necessarily solid copper. Far from it.
In a jumper type situation, its all about the difference in voltage between the jumper battery and the battery being jumped. The new lithium batteries are pretty good at initial surge voltage which helps a lot in a jump situation.
Chum lee
