full_mosey
Nov 21, 2013Explorer
landyacht318 wrote:
When i turned my battery switch to both, bringing the AGM northstar into the loop, the draw from the Crown dropped to 0 and all the current was flowing from the AGM which was at ~12.9v.
I don't know who said anything about cycling a starting battery. Just because it is in my engine compartment does not mean is is a starting battery. I have not owned a pure starting battery in 12 years. My engine requires a 650 CCA battery, and I've had a 600 CCA Marine wally world -27 battery in there for the last 7 years
I guess we'll see how my strategy of less capacity works out.
Please do not keep the AGM and wet connected full time. The wet will, at a minimum, suck the Volts from the AGM until the two reach equilibrium. This leaves the AGM at about 75% SOC and will result in sulphation of the AGM due to chronic undercharging. You now have two banks, not one. Why not two matching, wet or AGM?
AGMs are hybrids. Does this read like a starting battery spec? "Cycles over 400 times to 80% depth of discharge". That equates to camping every weekend for 8 years with an 80% drawdown every time.
Yep, I also subscribe to the smaller is better for bank size and agree with your analysis. Lions and Tigers and.... :)
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
