MEXICOWANDERER's avatar
Oct 17, 2017
"Pet" Subject: Vacuum Panel Insulation cut n paste
Does Vacuum Insulation Make Sense?
To insulate refrigerators, perhaps — but to insulate buildings, probably not
Posted on Nov 14 2013 by Alex Wilson
Image 1 of 3
Microtherm's vacuum insulation panel has a microporous substrate covered with an airtight aluminum skin.
I’ve recently worked on revising the BuildingGreen Guide to Insulation Products and Practices (available as part of a webcast), so I’ve been steeped in all sort of insulation materials, including some oddball products. One of those is vacuum insulation — the principle of a Thermos bottle.
In theory, vacuum insulation is a great idea. To understand why, it helps to know a bit about heat flow.
How a vacuum slows down heat transfer
There are three modes of heat transfer: conduction, convection, and radiation, and if we remove most of the air molecules from a space — as occurs when we draw a vacuum — we largely eliminate the first two of those heat transfer mechanisms.
Conduction is the flow of heat from molecule to molecule. It’s the reason a cast-iron skillet handle heats up. But thermal conduction also occurs across a layer of air, as kinetic is transferred from one air molecule to the one next to it. If we remove most of those air molecules by creating a vacuum, there will far less conductive heat flow.
RELATED ARTICLES
A Few Product Highlights from GreenBuild
GBA Product Guide: Dow Corning Vacuum Insulation Panels
Convection is the transfer of heat by moving molecules from one place to another. Warm air rises, and these convection currents carry heat — for example, this is the primary means that heat is delivered to a room from baseboard convectors (often called radiators). In a vacuum there are far fewer air molecules, so convection of heat nearly stops.
Only radiant heat flow occurs to a significant extent in a vacuum, because radiation is not dependent on air molecules. That’s why low-emissivity surfaces are so important in vacuum panels. The Stanley Thermos bottle has a very shiny, low-emissivity (low-e), inner surface that helps to control radiant heat transfer; the same sort of low-e surface is included in various vacuum insulation panels.
The net result is that an inch-thick vacuum insulation panel can provide a center-of-panel insulating value of R-25 or even more — compared with R-6 to R-7 for standard rigid foam insulation.
The “hardness” of a vacuum
The key property of a vacuum is its pressure, or how “hard” it is. We often measure that with Torr units. One Torr is exactly 1/760th of a standard atmosphere (1.3 x 10-3 atm), or approximately 1 mm of mercury. With a very hard vacuum, more of the air molecules are sucked out, resulting a greater negative pressure. The walls of a typical Stanley Thermos bottle contain a relatively hard vacuum of 10-6 Torr. With such a hard vacuum, that Thermos bottle can keep coffee hot all day. By comparison, the vacuum in a flat vacuum insulation panel is typically no more than 1/1000th as strong (10-3 Torr).
The harder the vacuum, the more difficult it is to maintain it. Thermos bottles are made with a cylindrical design for optimal strength. With flat panels, it’s very hard to achieve comparable strength and maintain such a hard vacuum, particularly at the edges.
Using a vacuum to insulate more than our coffee
If a vacuum works so well to keep our coffee hot all day, why not use one to insulate our houses? Vacuum insulation panels have been used to insulate some high-tech demonstration homes, such as entrants in the Solar Decathlon student design competition in recent years, but high cost makes them impractical for real buildings.
There’s also the problem that puncturing that vacuum insulation panel will significantly reduce its insulating performance. (I can imagine how bummed one would be after spending thousands to insulate a home with vacuum insulation panels and then hearing a hiss while hanging a painting!)
However, these vacuum insulation panels (sometimes called VIPs) could make a great deal of sense in certain value-added products like refrigerators, freezers, water heaters, and entry doors. Whirlpool actually used a VIP that Owens Corning produced for a while (the Aura panel) in a high-efficiency refrigerator in the mid-1990s, but then dropped both the refrigerator and the use of VIPs.
But I believe the benefits of R-25 or more in a one-inch-thick panel are significant enough — especially as we try to get more usable volume in refrigerators without growing the exterior dimensions — to warrant the embrace of vacuum insulation. These could also be a great solution for exterior doors that are notoriously poorly insulated — as I’ve written about in this blog.
There are at least a half-dozen manufacturers of vacuum insulation panels today. Most, including Microtherm and Nanopore, produce panels that have a rigid, porous substrate surrounded by an impermeable metal skin.
A new VIP on the market
The latest VIP to come along is made by Dow Corning (no relation to Owens Corning). This panel, not yet widely available, is one inch thick and has a center-of-panel insulating value of R-39 and a “unit R-value” (accounting for the edges) of R-30, according to the company.
The Dow Corning product has a core made of fumed silica cake, a remarkable “microporous” material that provides R-8 per inch even without a vacuum. This material allows a very high insulating value even with a softer vacuum. The core is reinforced with silicon carbide and polyester fibers for structural support, and it is encased in an inner layer of polyethylene and an outer layer of polyethylene, polyester, and aluminum. The panels are vacuum-sealed, and the edges are heat-sealed.
According to an Environmental Building News article, these Dow Corning panels should cost $10-12 per square foot. At that cost, I believe VIPs can be very practical for those appliance and exterior door applications noted above.
Alex is founder of BuildingGreen, Inc. and executive editor of Environmental Building News. In 2012 he founded the Resilient Design Institute. To keep up with Alex’s latest articles and musings, you can sign up for his Twitter feed.
Read more: http://www.greenbuildingadvisor.com/blogs/dept/energy-solutions/does-vacuum-insulation-make-sense#ixzz4vnfONKc5
Follow us: @gbadvisor on Twitter | GreenBuildingAdvisor on Facebook
  • Aboard sloops, ketches, and multihulls, they can take shocks that almost hurt the feet. I may be wrong but I have a feeling a majority of new construction vessels use vacuum panels as well as having hundreds of retrofits done annually.
    Gossip is rife that an inch of vacuum panels = 8" of open cell foam. To clad entirely an RV refrigerator would more than likely reduce energy consumption 90%. No gas refills every two weeks. Try nine months if the door gasket has been improved.
  • I wonder how they would react to twisting and vibration in an RV?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
