C_Schomer
Nov 30, 2014Explorer
PI power mgnt system w/Honda generator.
My 5er had the Progressive Industries when I got it and now I have a Honda 2ki gen. The PI doesn't see a gnd. when running on the gen (floating neutral) so it shows E2 error - no gnd and I have to hit the bypass switch on the PI module to force the contactor closed. The PI doesn't show volts/amps/hz in bypass and I would like to see that while running on the gen. I tried a gnd jumper from the gen to the 5er but no dice. With land power, neutral goes to gnd in the main panel, so the PI sees that and works right... I guess. I don't want to tamper with the Honda but I'm thinking that floating neutral is the problem. Has anyone bonded neutral to gnd on there Honda or figured out how to make the PI show it's information in the bypass mode?
I could call PI next week but I'm impatient! Craig
