Bill_Diana
Mar 19, 2015Explorer
Here is my undstanding as to what I can expect when they take my motorhome into the RV Roof shop. They will inspect the roof to determine if the old rubber needs to be removed. They will examine for soft spots that may necessitate plywood needing replaced. All vent covers and caps will be removed, including the AC shroud, refrigerator and sewer vents. All caulking will be removed. All the prep work is done on day one. The price does not include replacement of the shower skylight. They will replace the skylight if you want and only charge for material. Or they can coat the skylight if you desire. I'm keeping the exiting skylight and not having it sprayed.
On day two they spray the roof and install all new vent caps and covers. They do not spray the AC shroud...simply install the old shroud . They will spray down the sides as far as you desire.
They told me the new roof will add about 150 pounds to the RV. David told me the new roof will help some with the heat of the sun and also deaden the sounds on the roof some.
Hope this answers some questions. Please let me know if you have any more questions.
