dougrainer
Mar 19, 2015Nomad
I do NOT like the idea that they do NOT remove the top AC units. That is one place you DO find rotted areas when replacing a roof the CORRECT way. AND, you replace the AC seals and the other appliance mounts. The CORRECT replacement, you replace the roof vents(vent and refer) completely and the sewer vents completely. The only thing not replaced completely is the TV antenna/Sat dome. NOT removing the top appliances is NOT doing the job correctly. The added cost of those parts is less than $200. Regardless of what the FlexArmor shop states. Now, if they give YOU the choice between cheaper and the job done correctly at a higher cost, then I am OK with it. Doug
