RVRoof12
Mar 23, 2015Explorer
dougrainer wrote:
I do NOT like the idea that they do NOT remove the top AC units. That is one place you DO find rotted areas when replacing a roof the CORRECT way. AND, you replace the AC seals and the other appliance mounts. The CORRECT replacement, you replace the roof vents(vent and refer) completely and the sewer vents completely. The only thing not replaced completely is the TV antenna/Sat dome. NOT removing the top appliances is NOT doing the job correctly. The added cost of those parts is less than $200. Regardless of what the FlexArmor shop states. Now, if they give YOU the choice between cheaper and the job done correctly at a higher cost, then I am OK with it. Doug
We just wanted to clarify for people following this thread. We do removed the A/Cs, spray inside the opening and reinstall with a new gasket. We have a specialized system we created for reinstalling roof mounted acs such as those found on Newmars where the bolts are located outside the gasket. When we do your roof the price includes the replacement of all vent pipes and lids, refrigerator base and lid, standard vent lids, camco vent covers and new a/c gaskets. Anything such as satellites and solar panels are also removed and our system that allows as to mount them back without puncturing the roof is used.
If you ever do need to remove or add something, we can spray just that area. We are currently working on expansion and you will start to see authorized applicators in other areas.
