dougrainer
Aug 16, 2023Nomad
If the pilot stays lit, but burner will not light, the problem is the Oven Temp control assbly. Doug
PS, with the pilot lit, WATCH the pilot as you turn the Oven knob to 350 degrees(any temp). The Pilot flame should get BIGGER to heat the oven thermister. IF the flame does NOT get bigger, same problem, the Oven tstat assbly.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
