bob_nestor
Aug 20, 2023Explorer III
Doug is probably spot on with his advice, but the other thing that could cause something like this is the propane regulator needing replacement.
I had the same problem as the OP described - burners wouldn't stay lit. The refrigerator would work on propane but the propane powered generator wouldn't stay running. I replaced the regulator and everything was back to normal.
What I discovered in my research is there's a small bit of oil added to propane gas to keep things lubricated. Sometimes the propane supplier overdoes it with the oil and when that happens it collects in the regulator and basically reduces the gas flow to the point where appliances needing higher gas flow stop working.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
