myredracer's avatar
myredracer
Explorer II
Aug 10, 2014
Pinhole leaks in sewer hose - what to replace with?
Just discovered that 2 out of our 4 Valterra EZ Coupler hoses have pinhole leaks. Less than 3 years old and always stored in our pass-through compartment when not in use (with ends coupled). Never abused so not sure how this happens, although I believe it's not uncommon.
Are there better quality ones available? Maybe the Thetford Smartdrain or Camco Rhinoflex? I'd rather not have to replace our fittings but I do find the twist connections are hard to get on and off sometimes. Maybe Thetford and Camco connections are easier to do?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Rino Flex. is supposed to be better, I have replaced twice in 8 years though
    Valterra just came out with a "Smart Hose" Look and feel are excelent, too new to make serious comment and since I'm not using it where I am parked now it may be several years before I can comment personally.
    There is one I think called Drain master.. It is the last sewer hose you will ever buy, costs about 150 bucks as I recall but.. Lifetime warranty 100% (Hence the last comment, if it leaks, they repalce it)
  • If stored in your camper all year, the constant temperature changes alone will cause the plastic the hoses are made of to begin to break down (not to mention, in addition, all the chemicals that pass through your hose...yes, even dishwashing liquid will break stuff down if given enough time). After a while, even the slightest drag over a sharp tiny stone or a stick in the grass or even bumping into another hose in storage could cause the thinning plastic to begin to just, literally... wear out and begin to get pin holes.
    The only solution for longer life is a thicker mil hose which takes longer for the deterioration process to occur.
    If you can afford it, Rino hoses are pretty durable. But if you really want to get creative, you can always make your own. All you need is the end connectors and a 3 inch hose, like black field tile or even those plastic extension you can use at the bottom of the gutter down-spouts at your house. Actually, those are pretty tough if you want to take the time to make your own set. But they don't store very compact though.
    I did find some slinky style down-spout hoses that pull apart and pull tight again. I'm using those around my house for the down spouts. I'm seriously considering making a set of hoses myself out of that stuff. It's just an idea!
  • Don't let your sewer hose lay on the ground...little sharp stones & pebbles will poke holes...either get a slinkey to lay it on or cut a section of PVC in half so your hose can lay in it to protect it
  • I went with the Viper hose as I prefer the more pliable/flexible hose.
    At same time I moved to the 5" vinyl fence post storage method just so my new hose would stay nicer.
  • Slap some Duct Tape on that hose.
    My tooth Brush is older than 3 years..LOL
  • downtheroad wrote:
    Camco RhinoFLEX RV Sewer Hose.
    The rest are a distant 2nd.
    +1.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
