Chandalen wrote:
Seriosuly... wtf is wrong with posting... keep getting an error, but if i keep my posts to like 4 sentences its ok...
I would go with a PWM controller.
MPPT is usually out performed by PWM in smaller array sizes.
MPPT hates heat. A lot.
Any advantage MPPT could provide in a camper install is negated, or lost when you factor in heat, small array size, likely hood of actually angling the panels when you stop.
Use the saved money for lower gauge wires, a better inverter (PSW), etc..
But what do I know, Im just NABSEP certified.
"And the truth shall set you free"
Many here believe otherwise.
The only issue I have is solar nubbies getting misinformed.
