evy
Feb 12, 2016Explorer
Gdetrailer wrote:
one must ask the question..
Is it too "good to be true" on such a LOW, LOW price?
If it really IS worth $253, plus, plus then why is the seller trying to sell it for less than 1/3 of the "value"..
Kinda sounds like a scammer or stolen battery?
The second question is do you REALLY need the properties of AGM such as spill proof, high vibration resistance or high current charge/discharge rates?
You do realize that AGMs come at a cost of LOWER CAPACITY in Ahr and or CCA?
LOWER CCA might be of importance to you especially if you are trying to use it for STARTING in extreme cold temperatures..
The asking price was 200$ and she accepted 100$, her story is that she bought it for her old car and she wrecked it just before putting it in...
like I said I need AGM because the battery is under the bed with all the other electrical accessories, inverter, converter, charger, fuse boxes etc... and it's not a sealed nor vented area so I can't use regular acid batteries.
It will not be used for starting the vehicle.
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 14, 2025
