dougrainer
Aug 10, 2015Nomad
DHart wrote:dougrainer wrote:
As a Tech for an A/S dealer, I will bet the rear cooling fan is inop. A/S has Dometic add the rear 12 volt fan in their installs due to the way the roof curves and the fact of the aluminum sidewalls. To test, just open the rear outside door and install a 120 volt small fan blowing upwards for 24 hours. Then measure the temp again. You should also HEAR that fan if it is running. One of the biggest complaints we get from A/S owners is the sound of that fan running. They do not understand why they hear a fan. Doug
Looking in the outside mechanical compartment of the fridge, there is no fan anywhere to be seen, nor one to be heard.
The fridge is a Dometic DM2862LBX and the coach is a 2016 30' Serenity.
I just stuck a small 6" fan in there pointing upward. Hope to see if that makes a difference.
On your model, you will not see the fan easily. It will be up about 2 feet from the bottom and the lower coils will make it hard to see it. AS others have stated, there is NOTHING you can do. You need to get it back to the dealer and have them check it out to find the problem. You DO have a problem, and cannot be fixed by you. Doug
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
