Old-Biscuit
Aug 10, 2015Explorer III
lawrosa wrote:OP............
Your warm fridge is due to lack of outside fan operation and/or lack of proper installation clearances/airflow obstructions/dead air spaces.
RV absorption fridges require very narrow clearances so that air flow (Draft) is up/thru/across absorber tubes and evap/condenser fins
I highly doubt it in an airstream that its not installed correctly...
If you dont have a trap hot air will get in. The small drips in the tray flowing out the tube does not block the line.. You need a trap. You can gain 10 degrees just with that one fix.
Hot air is getting in if the OP dont have it..
Could be a door seal.
Could be a level issue.
IMO an extra fan is not needed. Solar roof one or one in fridge. Especially in a brand new airstream..
Maybe in an old unit caked with dust, no trap, weak element your just compensating...
Warm air is NOT getting into Freezer Section
Freezer is only getting down to 16*F
Dometic has been using that drain tube plug for decades.
Norcold uses a drip tray that drain tube sits in
Fridge has improper/insufficient air flow (DRAFT)
OPs Fridge comes with an external fan (LBX)
Fan is NOT working
Air flow is not correct.
And I don't give a rats patooty if it is an Air Stream, a Phaeton or and old Yellowstone rig.
OP is not going to get COLD temps until fridge air flow (lack of) is addressed and corrected.
Bandaid Internet fixes will NOT resolve OPs issues.........Period
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
