dougrainer
Aug 13, 2015Nomad
I made a mistake on your refer model number. The Model number MUST have an F in the model number for a Dometic installed fan. You do NOT have that fan(not really needed). On your model, the refer is NOT installed all the way to the sidewall. Due to the curved wall the bottom of the refer is about 10 inches IN from the outer door and that means the curve of the A/S roof is NOT a factor in removing convection air. The odds are, you have a bad cooling unit. I confused your model with the A/S models that have two side vent doors and no roof vent. Those models have the fan. Doug
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
