John_Wayne
May 30, 2013Explorer II
What does the Camp Chef say it needs for pressure? Your TT regulator should be set for 11 inches of water column. If this is what the camp chef needs your good to go by removing the regulator. Just remember the regulator has to go back on before you hook up to a gas bottle.
Can you put the connection from the trailer between the camp chef regulator and stove then you would not have to remove the camp chef regulator.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
