wa8yxm
May 30, 2013Explorer III
The Propane quick disconnect you show in the picture (lower right) is a High Pressure" type fitting, it is designed for propane under around 100 PSI of pressure (more or less depending on weather conditions).
It appears you have installed it on the LOW PRESSURE manifold. That is 11" of water pressure or about 1/2 PSI, not nearly enough to feed a high pressure grill.
(High pressure grills are ones designed to be fed by a disposable bottle or a tank with adapter hose)
If this is a trailer get a Marshall Brass "Extend-a-flow"
If it's a motor home,, then go with the Extend-a-Stay
the "Stay-A-While" by, I think Mr Hearer is an equivalent product to the Extend-a-flow from what I understand.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
