Gdetrailer
May 22, 2016Explorer III
kahoona wrote:
Hi
I have a problem with my 2002 Coachmen Mirada. It is on a 2001 F53 chassis. The low beams blink off every 2 seconds constantly. In addition to that the low beams come on when the high beams are turned on. They are not supposed to. The highs do not come on when the lows are turned on so it is not a crossed wire between the two. The headlamp pod has separate bulbs for high, low and daylight bulbs. This may not have anything to do with it but at the time when this started the bulb for one DRL blew and I did replace it.
I replaced the multi-function switch. Checked fuses. Checked relays. I pulled one headlight pod and checked it over but saw no problem with it. Having the wiring in those looms makes it hard to check. Where do I start? Are there traditional problem areas?
Any help or suggestions would be appreciated.
Check the ground wires going to the headlight bulbs, the grounds may be bad feeding voltage back to the other bulbs (or filaments).. You should find one single wire at each socket that does not go into the wire loom, follow it and it should terminate under a bolt 6"-12" from the bulb socket.. Remove the bolt and clean any corrosion from the wire lug and the bolt.
Blinking bulbs can be caused by too high of a wattage (IE high power bulbs) that the vehicle was not designed for.. Typically headlight bulb circuits use auto reset breakers instead of fuses..
Overloading the circuit with higher wattage bulbs will trip the breaker, the breaker interrupts the current and the breaker cools and resets. Lather, rinse and repeat.
