beemerphile1
May 23, 2016Explorer
kahoona wrote:
Hi
I have a problem with my 2002 Coachmen Mirada. It is on a 2001 F53 chassis. The low beams blink off every 2 seconds constantly. In addition to that the low beams come on when the high beams are turned on. They are not supposed to. The highs do not come on when the lows are turned on so it is not a crossed wire between the two. The headlamp pod has separate bulbs for high, low and daylight bulbs. This may not have anything to do with it but at the time when this started the bulb for one DRL blew and I did replace it.
I replaced the multi-function switch. Checked fuses. Checked relays. I pulled one headlight pod and checked it over but saw no problem with it. Having the wiring in those looms makes it hard to check. Where do I start? Are there traditional problem areas?
Any help or suggestions would be appreciated.
The part in bold most likely contains your answer. Whenever a problem arises, go back to the last thing done previously.
Wrong lamp? Inserted wrong? Defective lamp?
