MrWizard
May 23, 2016Moderator
grounds are the common suspect for many wiring problems
BUT when power blinks on / off at at regular timing intervals
i start looking for overload conditions on that circuit
do the DRLs stay on when the low beams come on ?
are they on the same fuse/reset breaker ?
if the answer to either is yes, then i would remove that new DRL bulb
and test the lights again, see if the problem changes
