kahoona
May 23, 2016Explorer II
MEXICOWANDERER wrote:
Ford has had chronic headlight switch problems since the 1970's.
Since then Ford has utilized RELAYS in the power circuit, but problems continue in the control switching circuit. If your control is on a turn signal stalk look for switch control problems at the switch itself. Yes it means pulling off the steering wheel.
My thoughts exactly so I did replace the multi-function switch on the steering column.
