kahoona
May 23, 2016Explorer II
MrWizard wrote:
grounds are the common suspect for many wiring problems
BUT when power blinks on / off at at regular timing intervals
i start looking for overload conditions on that circuit
do the DRLs stay on when the low beams come on ?
are they on the same fuse/reset breaker ?
if the answer to either is yes, then i would remove that new DRL bulb
and test the lights again, see if the problem changes
Thanks. I will keep overloads in mind. I'll see if they go out. I believe they should. The problem was there when I noticed the DRL was out and exists with the DRL removed.
