Max1
Feb 10, 2025Explorer II
Sounds like a glitch with your DC current monitor. First, try the basics: check all connections and fuses to make sure nothing’s loose or blown. If that doesn’t work, a system reset might help, turn off the power for a few minutes, then restart. If the issue persists, it could be a faulty sensor or control panel, and you might need to consult your manual or reach out to Pleasure Way’s customer support.
