RJsfishin
Oct 24, 2016Explorer
For all yous that condemm anything a factory does, what do you consider to be undersized wire ? In reality, 10 ga is good for 3-400 watts, which even in parallel, puts the running voltage from the panels at about 18 volts. And most the installs use series, which could then make 10ga wire overkill.
