Sort By
- Some rigs do not have Marinco style connectors. They are used more in marine applications. Plus they cost more!
- MEXICOWANDERERExplorerCut a notch in an upright 2x4
Endless variations like notches every 6"
2x6 option
It supports cord weight. Even a hundred pounds.
Been using this in México for 40 years - wa8yxmExplorer III
enblethen wrote:
Many rigs do not have a locking ring.
On 30/50 amp Marinco type connectors that I've seen there is always a locking ring. Two types.
now on 20 amp Twist lock. no ring but I've not seen one of those in a long time. - This would help relieve strain. Problem though with rigs that do not have locking ring as in previous posts.Marinco 90 degree adapter
- GjacExplorer III
enblethen wrote:
I have the 90 degree end on mine, non locking just plug in, it is extremely tight and is 24 years old. I have to wiggle it to remove it.
The weight of the straight twist lock connectors is a big factor. Yes, you can try to bend pins. Doubt whether it will last.
Most twist lock connectors are made of better material. They do not normally show burnt marks on pins. The end that becomes loose is on the cable. Replacing it with a 90 degree, hard to find connector can reduce strain on pins. - Many rigs do not have a locking ring.
- cavieExplorerafter you turn the plug to the right you MUST tighten the locking ring! you can bend the ped end but not the RV end.
- wa8yxmExplorer IIII'm not sure what you mean by "Loose" but I do not think you have a problem
Are you getting good power inside? If so likely no problem
I would not bend tabs to tighten
Tighten the lock ring - midnightsadieExplorer IIhave a good electric shop in your area,, cut it and have a new 90deg put on. might come close to the price of a new cord,or they might do it free. mine would do it free small town .
- YosemitebobrExplorerthanks guys. I'm convinced it is the twist lock connector. As stated by Bud, it is big and heavy. There is no way into this molded piece. The receptacle on the RV is in good shape. A right angle 50a connector would probably cost as much as a new cable LOL.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 04, 2025
