Gjac
Aug 15, 2020Explorer III
enblethen wrote:I have the 90 degree end on mine, non locking just plug in, it is extremely tight and is 24 years old. I have to wiggle it to remove it.
The weight of the straight twist lock connectors is a big factor. Yes, you can try to bend pins. Doubt whether it will last.
Most twist lock connectors are made of better material. They do not normally show burnt marks on pins. The end that becomes loose is on the cable. Replacing it with a 90 degree, hard to find connector can reduce strain on pins.
