dougrainer
Feb 28, 2015Nomad
Gene&Ginny wrote:dougrainer wrote:The old dryer outlets like mine look very similar to the RV outlets. Some electricians don't bother to read and assume they are the same ...... sigh ....
... Dryer plugs are NOT the same as a 30 amp RV plug. ....
RV 30 amp outlet
There is NO WAY to plug in a 30 amp RV male plug to a dryer 220 plug. LOOK at the Ground pin. You would have the modify (smash) the RV ROUND ground pin. IF you have to modify a male plug in any way to FIT the wall receptacle, that means something is WRONG. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
