AdvancedQs's avatar
AdvancedQs
Plumbing Confusion
A few months back my hot water heater bypass valve blew apart. Luckily I was in the RV when it happened so I caught it. Otherwise my entire water tank would have ended up on the floor in the RV. The body of the valve blew apart. This is under normal 12v pump pressure.
So I ordered a replacement Flair-It valve off Amazon. This exact one:
https://www.amazon.com/gp/aw/d/B002UCAE2U?psc=1&ref=ppx_pop_mob_b_asin_title
It had 2 settings. Flow through or divert. It didn’t let the hot water fill up on the flow through setting and I guess diverted fine.
So then I ordered this one. It has 3 settings. Pass through, divert and combine.
https://www.amazon.com/gp/aw/d/B00IRUNEIA?psc=1&ref=ppx_pop_mob_b_asin_title
One setting turns off my hot water entirely. The other 2 settings make it so I can feel some warm water coming through, but as the pressure of the line drops waiting for the pump pressure switch to engage, it goes cold.
I’m at my wits end here. I can’t see why these simple replacement valves aren’t working.
Any ideas? I’ve wasted $30 or so on this now. Getting so frustrated that it doesn’t work, but I’m just thinking of taking out the bypass entirely.
  • Thanks, this helps.
    1.The top(hot output) is the check valve. The bottom is not a check valve
    2. If you did NOT have the check valve on the Hot, in your system, when in bypass mode, the cold water would go UP that center pipe and then flow into the Water Heater from the top. As it is designed, when in bypass, it shuts water OFF to the cold input at bottom, then goes UP that center connecting pipe and when stopped by the check valve will then run cold thru the hot water pipes. So, NO water goes into the Heater tank.
    3. I WOULD suggest replacing the Brass check valve. They get mineral deposits and sometimes the "valve" itself gets cockeyed and restricts normal flow.
    4. Replace the check valve and I think your problem is solved. Doug
  • When I de-winterized my Airstream this spring, I was getting little water from the hot water tap. I took a wooden rod and gently tapped on the backflow check valve at the top of my water heater, and the hot water stream increased significantly. I think either that valve had stuck, or some detritus had partially clogged it up. When I tapped it it either unstuck, or the detritus flushed on out.
  • As said above, with the pump on, open the pressure release valve. You should get a lot of water coming out. Leave it open for a few seconds to ensure the flow continues. If you do not have good flow there, I would assume part of the broken valve may be in the section between the new valve and the tank blocking water flow. Easy to check by unscrewing fittings and looking. After draining the tank of course.
    If you have good flow out the pressure release valve I would unscrew the plumbing from the hot out and check out the check valve.
    As for the mixing of hot/cold water, you may have another issue going on. Check your shower to make sure the valves are closed (valves may be open with the button on the shower head turned off). Both the inside shower and the outside "shower". If these valves are left open it allows the mixing of hot and cold.
  • Thanks, Doug and everyone.
    I have normal flow out they release on the hot water heater outside the RV.
    So yeah. It’s the check valve doing something weird. The new one will arrive tomorrow and I’ll update the thread with some results once I get that in.
  • THREAD RESOLUTION:
    It was the check valve on the hot water heater. Now all of the water is coming out at a normal rate, and there is no more weird mixing of hot and cold.
    How exactly the check valve did that is still a mystery to me. But I did come out in pieces when I took it off.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
