AdvancedQs's avatar
AdvancedQs
Plumbing Confusion
A few months back my hot water heater bypass valve blew apart. Luckily I was in the RV when it happened so I caught it. Otherwise my entire water tank would have ended up on the floor in the RV. The body of the valve blew apart. This is under normal 12v pump pressure.
So I ordered a replacement Flair-It valve off Amazon. This exact one:
https://www.amazon.com/gp/aw/d/B002UCAE2U?psc=1&ref=ppx_pop_mob_b_asin_title
It had 2 settings. Flow through or divert. It didn’t let the hot water fill up on the flow through setting and I guess diverted fine.
So then I ordered this one. It has 3 settings. Pass through, divert and combine.
https://www.amazon.com/gp/aw/d/B00IRUNEIA?psc=1&ref=ppx_pop_mob_b_asin_title
One setting turns off my hot water entirely. The other 2 settings make it so I can feel some warm water coming through, but as the pressure of the line drops waiting for the pump pressure switch to engage, it goes cold.
I’m at my wits end here. I can’t see why these simple replacement valves aren’t working.
Any ideas? I’ve wasted $30 or so on this now. Getting so frustrated that it doesn’t work, but I’m just thinking of taking out the bypass entirely.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
