Oasisbob's avatar
Oasisbob
PLUMBING MOD ?
Has anyone replaced the fresh water drain plugs with valves? Same on FW tank drain line. We camp almost year round and often winterize several times a year.Can I get the parts at a big box home depot type store?
  • pianotuna wrote:
    Mine came from the factory with valves.
    Ditto, just pull the handle.
  • I cut mine off and installed sharkbite valves. Very easy to do and a great mod. They have been on for 5 yrs.
  • Simplest way is to unscrew what you have in the tank. Take it to the hardware store and figure out what they have to replace it with. I replaced the ball valve with a pencil sized hole they had in mine with a 1/2 inch fitting in the tank and a 1/2 inch ball valve.
  • I replaced the 3/8" drain with 1/2" drain. It is a lot faster to drain the tank now.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yes.on my RV not a problem... Some it might be due to placement.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
