joe0508
Jun 27, 2014Explorer
plunger switch
Is it possible to replace my kwikee step magnetic door switch with a plunger switch?If so how would i go about it?
joe0508 wrote:Chris Bryant wrote:So the controller will still know when to shut the power to the motor just like the magnetic one?
You just need to buy the correct plunger- older models (around pre-2000) used a normally closed switch, later used a normally open. The switch just connects to ground, so it's 2 wires, one from the brain, one to ground.
