joe0508
Jun 27, 2014Explorer
plunger switch
Is it possible to replace my kwikee step magnetic door switch with a plunger switch?If so how would i go about it?
Chris Bryant wrote:The reason for this is because I am having clearance issues between the magnet and switch.Do you think switching out with the plunger switch will cure my issue?joe0508 wrote:Chris Bryant wrote:So the controller will still know when to shut the power to the motor just like the magnetic one?
You just need to buy the correct plunger- older models (around pre-2000) used a normally closed switch, later used a normally open. The switch just connects to ground, so it's 2 wires, one from the brain, one to ground.
Yes- no problem. Here is a pdf file of the door switches, with Kwikee part numbers for 3 magnetic and one plunger.
