Grit_dog
Aug 31, 2022Trailblazer
wa8yxm wrote:Skibane wrote:wa8yxm wrote:
The side walls are just plastic sheeting over Styrofoam.. Just like the disposable coffee cup. Depending on the hole.. If it's just the plastic slap a square of Eternabond over it (They sell 11" by 11" patches) if it goes all the way through the foam insulation.. Well you might wish to fix that (no suggestions as to how)
A squirt of expanding urethane foam sealer ("Great Stuff" or similar) would probably come pretty close to matching the performance of the original insulation.
It expands a LOT as it cures, so use it sparingly.
I was thinking about that but that stuff is messy... I'd want to pull the fridge and apply it so I could trim and that's a bit of work (not as much as most folks think however... Really easy if you have two people one of whom knows how to do it.. (Been there. my RV-GIRL knows how to do it)
"Pull the fridge"? IE remove it to patch a hole in the inside plastic?
Considering the fridge is probably SUPER OLD, or even if not, I can't see how this would do any more than make a small problem bigger.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
