Hello all, Here goes my inaugural post! I've been reading this forum for a bit and found good advice before. Just like a lot of others, I've finally joined up to share/ask for some information. ...
Take it to the dump station, rinse and repeat. Hopefully you have a tank flusher built in. Never, never let it get that full again. You can damage the wood under the toilot as it leaks around the base. Only way to really check tank level is to look down the toilot when flushing. I am not a fan of chemicals but this may be needed. If you still smell sewer gas check the drain vent tube first of all. If the bowl holds water your flush seal is good
