chrispitude
Oct 13, 2018Explorer
dougrainer wrote:
While you have a lot of testing info. It does not really help. The SIMPLE thing is to have a qualified Dometic Service center do
1. Temp corrected amp draw of the compressor. This will tell you if the system is correctly charged and operating correctly for cooling
2. Verify and seal off those areas you stated the foil tape seemed to NOT be sealed correctly still.
3. Verify the Temp probe for the tstat is in the correct place. Doug
Respectfully, I disagree that my testing did not help. It confirmed that all the stuff you said is necessary. :)
