chrispitude
Oct 13, 2018Explorer
marcsbigfoot20b27 wrote:
Slightly important piece of info is missing....
What is your cold air output temp?
What is the delta......comparing air in to air out?
If you are only blowing lets say 68 degrees, or 55 degrees? this may help indicate which way to look. Blowing so cold (due to air remix) it is short cycling? Bad sensing bulb?
The delta T is the difference between the inside (darker) and outside (lighter) temperature curves. They are superimposed on the same graph.
Yes, I should have measured outlet temperature! I will get a reading on the next comparably warm day. With the crazy fall we've been having, that shouldn't take long.
