wa8yxm
Dec 13, 2014Explorer III
Step one: Disconnect hose from RV and open park faucet, run no more than one gallon to insure full flow out the hose.
Now, if you need to use a flashlight to inspect the inlet screen on the inelt hose washer.. It is very likely clogged, if it is either
1: Remove and replace (you can get replacement screen/washers at Sears (Appliance dept) or most RV stores).
or 2: Clean it and put it back.
Option 2: Even if there is no clog the lines are smaller than 1/2 inch so try a low-flow head.. I just put in an Oxygenics body spa and am happy with it, They make several models.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
