jrnymn7
Dec 13, 2014Explorer
Some or all of the rigs water lines probably need cleaning. Put a mixture of half and half vinegar and water in your fresh water tank. Run some thru the cold water lines, as well as thru the hot water heater and hot water lines. Then let it sit for a while. Then flush completely. This should be done yearly, regardless. You will likely see a white milky mixture coming out of your taps.
You can clean you coffee maker the same way.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
