CA_Traveler
Apr 06, 2014Explorer III
If that is 57.5 ohms to ground you need new heaters. Basically there should be infinite ohms to ground. If that's 58K ohms on a 200K scale then it's somewhat questionable.
Somewhat questionable??? Well the resistance is a static measurement. AC really involves impedance, changing conditions due to heat etc. But I digress...
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
