MEXICOWANDERER
Aug 12, 2013Explorer
Hi westend,
With a correctly maximum discharged (50%) group 29, I have instigated FIVE cycles of a Husky 40 amp battery charger and the charge level (acid SG went from 90 to 91 percent charged). I then tried EIGHT desulfation cycles on top of that and the SG did not increase on the hydrometer. So back went the charger for another. Same result. Tried a Black & Decker, not much different. I could not get the battery to fully charge. The maximum charge rate tapers too fast. Voltage droops down from 14.8 way too fast. What a waste of money connected to a generator.
So a DPDT relay connected to a timer now allows a 40 amp charge rate for an hour, switches the almost charger offline and the Harbor Freight online for 4 hours at the 2-amp rate, which usually starts out close to 8. By playing with the timer I can get a pretty full charge.
Yeah I know some three hundred dollar "smart" converters are better, but when I get serious, I slam 300 plus amps into my big battery bank, then taper at the last with the Harbor Freight set at 10 amps on a timer.
For me, common sense and a timer is hard to beat...
IT'S TIME FOR YET ANOTHER DOSE OF....
"The Harbor Freight charger DOES NOT WORK WELL ON AUTOMATIC MODE, and I do not trust it not to fail and destroy a battery. Period. With a dot.
Set the slider switch from AUTOMATIC to START. The dial is CHINAMERICAN mis-marked. START is in really MANUAL. You now have a manual charger, and this is where this charger shines. Superglue the switch to START if you have to."
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
