BFL13
Aug 15, 2013Explorer II
mena661 wrote:
BFL, what voltage are you using for a finishing charge?
I use the 1093 15.7v temp corrected at whatever ambient is.
However, on solar this summer, where the controller high point is 14.6v, and after it drops back to float and does that several days in a row, I have seen SG very near baseline, if not there when temp corrected for the warm weather. (I keep not doing temp correction)
So perhaps with shallow cycles like when on solar and low AH usage, they can get close enough to baseline without equalizing so you can't tell the diff. I wonder if it is the deeper cycling like in winter that makes it harder to get back up.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
