dougrainer
May 20, 2021Nomad
1. You DO HAVE a regulator. Period. While you see the Tank hose at the tank, there IS a regulator connected to that hose.
2. The Gas line at the pic of the Range, that silver thing is the Range Regulator and it is there to drop the RV LP pressure from 11.5 inches to 10 inches which is what most RV Range/Ovens operate at.
3. Clarify, IF the Range is inside the RV in its mount hole does it operate and light OK?
4. It only fails to operate correctly when mounted outside?
5. If mounted outside, can you light the burners with a match?
6. Last, from your pic, there does NOT appear to be a Piezo or auto ignitor system. Your Range must be manually lit with a match or flame. Doug
