wa8yxm
May 22, 2021Explorer III
Lynnmor wrote:
If that is a regulator where the copper line is attached, you cannot have two regulators, one at the tank and another in the stove. Possibly the wrong stove was supplied.
Not necessarly true
The RV has a primary regulator 11" of water is the pressure
And the stove often has a secondary regulator at a LOWER pressure.
To the original poster
First follow the lines to insure that both are low pressure ports (I suspect they are but check to be sure) also inspect the lines to the non-working port.
Then it is possible the external port has an issue.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
