Gdetrailer
Feb 16, 2019Explorer III
JusBud wrote:
So you're not a professional welder and yet I don't know anything at all and I'm supposed to listen to you?
Got it.
Let me rephrase and repeat my original post.
I don't want to use gas.
I don't want to look at the bigger picture.
I'm looking for a portable compact welder to get by in a pinch as I stated I have a friend that can fix it right when I get home.
I'm not starting my own business nor will I be welding everyday.
I don't want to spend $1000+
If someone comes here and asks about getting into a basic rv do you tell them to just get a Newell or Prevost?
:R
You do realize, MIG wire IS A HARD, HIGH TENSILE STRENGTH, it does not grind down easily so reworking it after the fact is a chore. Nothing like doing things the hard way twice.
Nothing like the joys of grinding off the junk MIG welds at home and redoing all of that work.. Your "friend" may not be your "friend" for long after they spend hrs grinding and redoing down your "handy work"..
You obviously have ZERO clue about welding, it shows by not listening to someone who has been doing welding home projects for 35+ yrs.
If you feel you NEED to do field repairs just to get home, I would not TRUST a cheapo shielded core MIG wire repair. For that kind of repair a small STICK welder is where you need to go. MIG welding does not do well with DIRTY material, grease, oil, RUST will PREVENT MIG welds from having penetration and strength. Stick welding on the other hand depending on what coating it has CAN make strong field repairs on dirty steel.
You can even make your own stick welder with two to three 12V batteries connected in series.. Just need a couple of heavy leads with a rod holder on one and a ground clamp on the other..
But, you obviously had you mind made up before you posted, WHY bother posing, you already wanted to buy junk, there is no reason to ask which piece of junk is "better".
Since you already had you mind made up, then just buy the cheapest HF welder you can get, there is no difference between the $119 HF welder and the $199 welder let alone the $400 welder you posted, there is absolutely no reason to spend $199, it will not produce any better welds than the HF one.
"Stupid is what stupid does" - Forest Gump..
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
