LittleBill wrote:
you need to decide if you need 240v
you need to decide if you care about fuel economy
you need to decide if you care about noise level
you need to see if you have sensitive electronics that require cleaner THD.
only you can make that decision.
A lot of rambling on with this thread but until the OP gives us this info, we can't give him good advice.
If you just want to run the fridge and a few lights, a portable 2000w generator is fine. If you want to run the whole house including the central air/con, you need something big and likely fixed install with a transfer switch and other complications.
Side Note: Looping around to the website we are on, a 7000w generator doesn't make a good "portable" for an RV in most cases (maybe if you have a permanent site with a place to semi-permanently install it).
