wa8yxm
Oct 27, 2013Explorer III
First, for the battery indicator with the row of LED's.. That can plug in to the booster-power supply, socket with no problem, it sips power (Few mA) and will not even be noticed by the booster or it's power supply.. DO NOT, however, plug in a trouble light, inverter or anything drawing more than a few amps.
The 50 amps, reffers to yoru 120 volt service, 120/240 volt at 50 amps is POSSIBLE if the park provides it, that's 12000 watts of power. So I use up to four 1500 watt "Cube" heaters (These are what about six by 10 or inches or so)
NOTE: I put in heavy duty outlets for them however, I seriously do not trust what came with the RV for that kind of load save for the washer/dryer socket (Which I use for one of 'em)
If you want to know how much battery you have.. You are going to have to tell us
Size of battery
How many
Size of battery
How many
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
