2oldman
May 08, 2017Explorer II
I don't know if 30ft is enough - probably cutting it close if you're a tree camper. I'd consider putting those panels in series if you go longer to cut down on line loss. Your controller will handle it.
I don't see the need for fusing panels; some do.
If series you can eliminate #2. Size #6 to whatever an amperage chart suggests.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
