RJsfishin's avatar
RJsfishin
Portable Solar Controller
I could use this on a on a portable panel to charge my scooter, and other stuff other than RV.
Does anyone recognize the plug opposite the battery end on this thing ? It seems like it would have an M4 connector on the input end, but sure don't look like one. And I kinda hate to chop the connector off a brand new controller. But it needs a 2pin, same as other end, w/ an M4 adapter, or an M4 panel connector. What you think ?http://www.ebay.com/itm/Instapark-INCC1205-12V-5-Amp-PWM-Solar-Panel-Power-Charge-Controller-Regulator/161388837382?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D26263%26meid%3D47c0e75010a24751aa684cc52772f06b%26pid%3D100033%26prg%3D10942%26rk%3D1%26rkt%3D4%26sd%3D161388837382
  • Sorry, I failed to see that adapter that adapts it from the round power plug to any twin lead you wanted to use.
    It is exactly what I can use for a battery charging panel,....I'll just add the M4s, call it an inline charge controller,....good for 100 watts.
  • Features:
    Brand new and high quality.
    With over charge, over discharge, short circuit, overload protection, anti-reverse protection funtcion.
    Can be used for all panels.
    Fail safe and cannot be damaged by accidental wiring mistakes.
    Advanced design with simple plug and play technology. No need for complicated adjustments.
    PWM charge mode & state of charge(SOC).
    Dual-LED display.
    Work voltage: 12/24V.
    Rated charge current: 10A.
    Rated load current: 10A.
    Boost charge voltage: 14.6V;×2/24V.
    Direct charge voltage: 14.4V;×2/24V.
    Float charge voltage: 13.6V; ×2/24V.
    charge return voltage: 13.2V;×2/24V.
    Charge method: PWM.
    Operating temperature: -35? ~ +55?.
    Size: 13.5cm x 7cm x 3.5cm.
    Package Included:
    1 x Solar Charge Controller
    1 x User Manual
    $15.75 Flee Shipping
    http://www.buyincoins.com/item/41399.html
  • I think I'd buy a real charge controller.
    It looks like it comes with an adapter to let you hook up two bare wires. It all looks pretty cheap, like something I would have bought as a kid from Radio Shack in the '80s.
  • They might have something really nice if they put some 10 gauge wire on that and made it a 20 or 30 amp adjustable bulk charge voltage portable controller. 5 amps is mouse nuts.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
