AStinker-'s avatar
AStinker-
Portable Solar Panel Question
I want to put together a portable solar system to experiment & learn with this summer to decide if I really want solar. My goal is to get as many watts as possible but keep the weight per panel under 20 lbs. I was looking at Product A and B listed below and was getting ready to order Product B when I decided to look for some other lower priced 100W panels. What I found was most other 100W panels weighed more( Example: Product C ) than Product B. I am ignoring the cost per watt delivered to my house in this scenario but left it in because I am guessing someone will ask. I am also ignoring the fact that portables can walk away, won’t be usable while traveling, probably won’t get used because I’m lazy and in general are a PITA.
So my questions for you guys is:
1) How much does the weight of a solar panel affect the quality?
2) Is there other factors in the specs of the 3 panels listed below that should be a bigger factor in influencing my decision?
Product A
Manufacturer: W Solar
Max Power: 75W
Open Circuit Voltage (Voc): 23.36V
Short Circuit Current (Isc): 4.17
Maximum Power Voltage (Vmp): 18.0V
Maximum Power Current (Imp): 4.28A
Weight: 15 pounds
Dimensions (inches): 38.61 x 23.79 x 1.17
Cu Inches: 1075
$1.40/watt
Product B
Renogy Solar Panel
Maximum Power at STC: 100 W
Open - Circuit Voltage (Voc): 22.5 V
Short- Circuit Current (Isc): 5.75 A
Optimum Operating Voltage (Vmp): 18.9V
Optimum Operating Current (Imp): 5.29 A
Weight: 16.5 lbs
Cu Inches: 1402
Dimensions: 47 x 21.3 x 1.4 in
$1.50/watt
Product C
Manufacturer: Solar Cynergy
Max Power: 100W
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 6.30A
Maximum Power Voltage (Vmp): 17.0V
Maximum Power Current (Imp): 5.80A
Weight: 25 pounds
Dimensions (inches): 44.00 x 26.50 x 1.25
Cu Inches: 1458
$1.31/watt
  • "At today's prices" is correct unless you are a poor newbie wandering in the wilderness. Yesterday, I was in an RV shop in Parksville where they had a 145w "kit" for sale at a mere $675.
    I asked the guy what that was about and he said they got a "smoking deal" on those which is why the price. I said you can get the panel around here for $200 (actually not, but you can get a 100w for $125, so call it 200w for $250) and the controller for $30 plus pay whatever for the other bits and pieces.
    In fact, still out of sight for price, but just down the road a ways, the same kit is going for $509
    http://www.wegosolar.com/products.php?product=145-Watt-Solar-RV-Kit-with-30A-Flush-Mount-Controller
    He got sort of angry looking and stomped out to go check around his collection of trailers for sale, while I went my way. I don't think I will shop at that RV place anymore for parts! :)
  • Almot's avatar
    Almot
    Explorer III
    The heavier of B and C also has 10% larger area. Which simply means - less efficient per sq.ft. Though, being not 10% but the whole 50% heavier, it most likely means - better frame and/or thicker glass. A stronger product, in other words.
    It is interesting that they put Cu.inches in the specs - to me this number is non-informative.
    Isc doesn't mean much, with MPPT controller. With PWM - yes, it does.
    Btw, I will never understand why somebody would NOT want a solar, at today's prices. Bolt 200-300w to the roof and forget about it. It may or may not be the only or the main source of power depending on your situation, but there is no loss here. It will be charging your batteries in between (and sometimes - instead of) generator runs. Though, 100w is more a supplementary energy source, not something to rely on.
  • Weight does not affect performance as such, where exra weight might be in a heavier frame. Check frame depth in inches. some are 1 inch some are 1 1/2 inch. Sometimes a stronger panel frame is good if your portable stand contraption is not strong.
    You care about the Isc rating in amps because that is what you should expect with a panel pointed at a high sun.
    Your list:
    A. You seem to have the Isc and Imp reversed
    B. Isc is low for the wattage, see
    C. Where Isc is correct for a 100w panel (6.3a)
    IMO C is the better choice here.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
