Almot
Mar 13, 2014Explorer III
The heavier of B and C also has 10% larger area. Which simply means - less efficient per sq.ft. Though, being not 10% but the whole 50% heavier, it most likely means - better frame and/or thicker glass. A stronger product, in other words.
It is interesting that they put Cu.inches in the specs - to me this number is non-informative.
Isc doesn't mean much, with MPPT controller. With PWM - yes, it does.
Btw, I will never understand why somebody would NOT want a solar, at today's prices. Bolt 200-300w to the roof and forget about it. It may or may not be the only or the main source of power depending on your situation, but there is no loss here. It will be charging your batteries in between (and sometimes - instead of) generator runs. Though, 100w is more a supplementary energy source, not something to rely on.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
